MarcusPizzorno
#1 Posted : Wednesday, December 2, 2009 11:36:30 AM(UTC)
MarcusPizzorno
I have ordered a Defrost heater. (My approach is somewhat Shot Gun but the refridgerator does NOT roll forward; it needs to be lifted in and out of the space and takes two guys.)
How do I get to the Defrost Heater?!
Thank you for this forum.
Marcus
P.S. I did buy the Defrost Heater from AppliancePartsPros.
gmbdinc
#2 Posted : Wednesday, December 2, 2009 12:33:57 PM(UTC)
gmbdinc
Marcus
The defrost heater us usually located under the evaporator behind the back wall of the freezer. Remove the shelves, remove the screws and air baffels if it is a top freezer, then look to the bottom of the evaporator, there it is.
#3 Posted : Wednesday, December 2, 2009 3:09:15 PM(UTC)
The defrost heater is shown as #230 on the diagram. As gmbdinc said, it is under the evaporator, behind the rear panel in the freezer.
gmbdinc
#4 Posted : Thursday, December 3, 2009 7:05:34 AM(UTC)
gmbdinc
Something else you might check before you install the new defrost heater is check the continuity on the old heater before removal and check the defrost thermostat continuity. I have found many times the defrost thermostat is the real culprit. Check it by allowing it to freeze, that allows for continuity. Hold it in your hand and wait for a "Click" while it warms up to insure it breaks the continuity on its own. Thanks to Gene for adding the diagram I have not got the skill to do that just yet.
Guest (4)
