stgbruced
#1 Posted : Friday, August 17, 2007 8:10:37 PM(UTC)
stgbruced
I trying to replace the outer tub. I have removed the pulley off the spider
shaft but I can not pull the spin basket from the front of the outer tub
assembly.
stgbruced
#2 Posted : Sunday, August 19, 2007 4:04:39 AM(UTC)
stgbruced
I now have the spin basket removed, but I can not remove the spinner support with shaft from the bottom of the outer tub. The outer tub is out of the washer with the retaining bolt and drive pulley are removed.
Guest (4)
