alexcorea
#1 Posted : Tuesday, December 1, 2009 3:24:24 PM(UTC)
alexcorea
I know that you need to take the burner off , one of my friend took the burner with a wrench and bend the gsa pipe supply ..ow can i take this burner without damaging the burner and etc..please help my oven is not working and I replaced the igniter and still not working so i think is the Spark module
#2 Posted : Tuesday, December 1, 2009 5:35:00 PM(UTC)
What is the complete model number of the range?
What exactly is the problem: oven, surface burners, igniter? Can you be more specific on the problem?
alexcorea
#3 Posted : Tuesday, December 1, 2009 5:58:06 PM(UTC)
alexcorea
thank you for taking your time gene!i have a thermador oven that is not working...i replaced the igniter but still not work so i will replace the ignition box<spark module>....my friend was trying to replace one just like this..he could not get the hex in the burner to get to the module so he broke thelittle gas supply under the burner ,,i head if they are to tight that might happens ,,,so i need help since i never change one of this.how to install..
model #prg364edg/05
serial#39705008503
acorea71@aol.com
#4 Posted : Thursday, December 3, 2009 6:56:44 PM(UTC)
It's still not clear where is the problem: the oven or the surface (top) burners?
If you are talking about the oven then it has nothing to do with the spark module.
