bought replacement oven therm. and it has three sets of dip switches instead of two like the oem part.. double checked thru maytag and whirlpool and it all says the same part #....need schematic for this unit... wiring diagram or some expert advice....
You can find the wiring diagram on the break down diagrams for the Magic Chef range Model CER1140AAWIf you can post the pictures of the old and the new thermostats it might help to figure out the right wire connections. Gene.
