HaroldL
#1 Posted : Monday, November 30, 2009 10:33:57 AM(UTC)
HaroldL
The agitator in the ice cube container will not rotate when I despress the lever to get ice, thus ice is not dispenced. The water comes out fine. The light comes on, the delay closes the chute cover. I cannot turn the hex shaft with a socket wrench. I am assuming it is the motor 3776020. I have had the front off-the plastic cover that covers the controls, can see the levers-if I remove the levers, can I remove the next enclosure and get to the motor? Thanks.
#2 Posted : Monday, November 30, 2009 3:05:05 PM(UTC)
The instructions are attached to the reply.
- The motor Part number: AP3776020
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSRG25FKSS15 Refrigerator | AppliancePartsPros.com
File Attachment(s):
Troubleshooting the motor (in-door ice).doc (348kb) downloaded 38 time(s).
HaroldL
#3 Posted : Monday, November 30, 2009 3:24:33 PM(UTC)
HaroldL
Gene-thanks for your quick reply--my question is how to get to the motor. I have the diagram and part number but want to know if I access from the front of the door or do I need to take the inner liner of the door out? Thanks for what you do. Harold:)
#4 Posted : Monday, November 30, 2009 8:02:48 PM(UTC)
Quote:
... but want to know if I access from the front of the door or do I need to take the inner liner of the door out?...
You'll find the complete instructions in the first file attached to the previous reply.
HaroldL
#5 Posted : Friday, December 4, 2009 6:29:11 AM(UTC)
HaroldL
First off, I am impressed with the response and the links that helped me get the motor out and understand the circuitry. So, I have the motor out, the drive for the shaft will not turn by hand, I have put 110 AC V to correct terminals, no movement and I have jumped the two that come from the cube switch, still no movement. My problem---I cannot get 115 V DC on either of the wire harness contacts from the cube and crushed controls, beyond that I do not get 115 V DC on either of the terminals in the back of the control panel--for either cube or crushed. I think that I am over my head. Is there a way I can run the motor on a bench or do I need a DC 115V Power Supply to do that? Again, I am impressed with this site, Thanks again for the help. Harold
#6 Posted : Friday, December 4, 2009 1:54:29 PM(UTC)
Harold,
Sounds like the motor is bad.
Also, looks like the dispenser electronics is bad as well due to the dispenser has built in inverter which converts the AC voltage to the DC voltage and your test shows missing DC voltage.
- The dispenser front cover assembly Part number: AP3135525
HaroldL
#7 Posted : Monday, December 7, 2009 7:55:17 AM(UTC)
HaroldL
Thanks for all of your help--I had the motor on the workbench, removed and found water-----thought maybe it was froze up. Wow, it works. Without your help I would not have had it removed. Great service, thanks again. Harold
#8 Posted : Monday, December 7, 2009 1:40:39 PM(UTC)
You are welcome, Harold. I'm glad you were able to fix it with no cost to you.
Guest (12)
