dralonso
#1 Posted : Thursday, February 21, 2008 10:52:52 AM(UTC)
dralonso
everything electrical works, but blows only cold air. no heat.:confused:
kooler
#2 Posted : Thursday, February 21, 2008 4:09:27 PM(UTC)
kooler
Check incoming power for 240 volts at the dryer receptacle and at the terminals where the power cord connects to the dryer... If 240 volts is present here then dryer disassembly is necessary to further troubleshoot the circuit using an ohm meter... Check the heating elements next...
#3 Posted : Thursday, February 21, 2008 4:40:05 PM(UTC)
In addition to the advise given by kooler I would recommend to perform the troubleshooting described in one of my previous posts: http://forum.appliancepartspros...3-no-heat-gas-dryer.html
Here are the break down diagrams for the Whirlpool dryer Model LGR7646EQ3
dryer does not heat up as high as it use to (Dryer Repair)
by bubba1915 3/8/2014 5:49:40 PM(UTC)
Kenmore Elite Dryer does not heat up (Dryer Repair)
by cjagadheshan 12/13/2011 5:11:32 PM(UTC)
by liz777 1/6/2011 9:11:35 PM(UTC)
by kamputty 4/11/2010 8:40:39 PM(UTC)
by pauleouellette 3/10/2009 12:37:59 PM(UTC)
by bseibes 8/28/2008 6:59:14 PM(UTC)
dryer does not heat up (Dryer Repair)
by tkeemm 2/27/2008 6:37:29 AM(UTC)
