kenneth230
#1 Posted : 15 years ago
kenneth230
Control panel lights not working after self clean.
Does not show temp, but the clock keeps time, but fades in & out.
Oven comes on at 350 but controls do not show temp.
Is the problem circuit board or control board?
This oven has hardly been used.
Any help appreciated . Ken
#2 Posted : 15 years ago
Ken,
Sounds like the problem is a bad control board.
- The control board (microcomputer) Part number: AP3873768
kenneth230
#3 Posted : 15 years ago
kenneth230
Gene, Will it be a big problem for a semi-skilled handyman to change this control board? Any special tools needed? Ken.
#4 Posted : 15 years ago
Ken,
I do not think this job is going to be too difficult and you do not need any special tools.
The first step is to remove the oven side trims. Open the lower oven door and remove the screw from each side trim. Remove the side trim by pulling the bottom out approximately 2", and slide the top down to free it from the control panel.
I'm not certain on how to remove the control panel on this particular model. It looks a little bit differ with most others, but I believe it's not going to be very complicated. If it would, post some pictures.
whirlpool range GS395LEG (Oven Repair (including Ranges and Cooktops))
by Guest 12 months ago
whirlpool range Model xfg374lvs (Oven Repair (including Ranges and Cooktops))
by Guest 2 years ago
I have a whirlpool range Model #WFG505M0BS3 (Dishwasher Repair)
by Kbarbie 3 years ago
Whirlpool range GR399LXGT2 (Oven Repair (including Ranges and Cooktops))
by Guest 3 years ago
Hidden bake element whirlpool range (Oven Repair (including Ranges and Cooktops))
by Guest 4 years ago
Whirlpool Range issue (Oven Repair (including Ranges and Cooktops))
Whirlpool range oven doesn't heat (Oven Repair (including Ranges and Cooktops))
Whirlpool range touchpad won't display (Oven Repair (including Ranges and Cooktops))
by kleindon 7 years ago
No bake, no broil on Whirlpool range. Help! (Oven Repair (including Ranges and Cooktops))
by JamesTheScot 10 years ago
Whirlpool range supply voltage problems (Oven Repair (including Ranges and Cooktops))
by TheSunny1 10 years ago
Whirlpool range cooktop won't work code 79 (Oven Repair (including Ranges and Cooktops))
by jdgough624 10 years ago
Whirlpool range no digital display or oven working (Oven Repair (including Ranges and Cooktops))
by bdbwtie 11 years ago
Whirlpool range door won't open. (Oven Repair (including Ranges and Cooktops))
by Electechab 11 years ago
whirlpool range top not working (Oven Repair (including Ranges and Cooktops))
by bck621 11 years ago
Whirlpool range (Oven Repair (including Ranges and Cooktops))
by AlanO 11 years ago
