mikehi
#1 Posted : Sunday, November 29, 2009 12:42:49 PM(UTC)
mikehi
We own a Kenmore 106.41212101 refrigerator/freezer side-by-side purchased new in Feb 2004. First service call was in 07. The fan motor was dying of bearing failure. Fan motor was replaced with a replacement unit that looked different from the original part.
Second service call was Nov 24, 2009. Relay had smoked causing compressor not to run. Relay was replaced. Technician told me that the replacement fan motor from the first service call was a good unit that should give no trouble. He said reason first fan motor failed was because government mandate required manufacturer to use a smaller motor with a lower current draw. Smaller carbon footprint, in other words. Now that the fan motor is replaced with the correct unit (which draws more current) that the technician had to drive 120 miles to replace, how does this lower the carbon footprint?
We got to pay for the fan motor because failure was out of warranty. In my opinion this failure is a case of unwarranted government tinkering in my life.
If I replace this refrigerator the next time it breaks, will I even be able to get a more dependable unit? Call me a disgruntled user.
Mike
#2 Posted : Monday, November 30, 2009 1:39:08 AM(UTC)
Here is a tech sheet that may come in handy in the future.
http://www.servicematters.com/d...0Sheet%20-%202255374.pdf
The unit you have is fairly reliable, you have just been unlucky. It is actually a Whirlpool.
If you want to see problem units take a look in this forum at the number of GE's which use a control board. Then if your fan had blown you may have also had to replace the control board.
Quite frankly I think he is full of it. The reason it failed was Whirlpool may have tried to save a couple cents and used a cheapo fan. Or the fan's manufactured gave them false reliability data. They then saw a high failure rate and replaced it with a better fan. In a perfect world they would have at least paid for the fan as it was their mistake.
It is not only the government, many people look at the Energy Star rating and use it as part of their decision on what to buy so manufacturers are trying for the best ratings.
I do agree with you that in some cases it is total bull as many of the units that have better ratings will have more service calls and will end up in a land fill sooner. So the real carbon footprint over the units life is much higher than that stated on the sticker as it does not include the resources used to manufacture it. It all comes down to buyer beware.
I doubt it. You have a nice, simple unit and in my book simple correlates to reliability and life expectancy.
mikehi
#3 Posted : Monday, November 30, 2009 7:19:58 AM(UTC)
mikehi
I appreciate your reply. I was angry at the situation and this was a bit of sanity that I needed.
Mike
