Linda Arsenault
#1 Posted : Saturday, November 28, 2009 5:53:20 PM(UTC)
Linda Arsenault
I have a GE Profile Artica (Model # PSS25SGNBS) which has a digital thermostat inside the unit. About 2 months ago, I noticed that the food in the refridgerator was freezing, even though I kept the refrigerator portion set at the recommended temperature (37 degrees). The temperature fluctuates between 30-36 degrees; which is freezing the food. I even tried bumping the temperature setting to 42 degrees with no change. I have also noticed water leakage from the freezer periodically all over the floor. Any ideas what is causing this and how to fix it?
#2 Posted : Sunday, November 29, 2009 2:50:25 AM(UTC)
If all the fans are working, I would get a pro. to look at it, probably low on refrigerant.
