2 hours may be normal depends on what cycle type you are using.
Check that the water level is OK, most GE's fill to just under the heating element. Though if it was low water level I would expect you would also see that the dishes are not properly cleaned.
Check that the heating element is OK. |
THIS FORUM IS DEAD!!!!!!! |
