My top burners will not lite with the igniters, I can lite with a match. The oven works fine. Any help would be appreciated.
Did it click when you turn any knob "on"?
If it did click but did not light the burner then check the burner igniters for any damage to the ceramic part of the burner igniter.
If no one did not click then the spark module has to be replaced.
Before we go further I need you to answer on the above questions.
It Did Not Do Any Clicking.
how hard is it to change out this part?
