The machine was left unused for 6 months. When I tried running, all the sudden stopped working. There is no power coming to the panel. I opened the lower panel and used the meter to check for continuity. Unable to identify the fault. I observed one brown discolored burnt wire connected via a terminal, passed continuity test. Unsure what caused this burnt wire? I contacted a local parts supplier and was told it maybe the timer. I hate to be shooting darts in the dark for possibly buying a timer and finding out this didn't fix my problem. I have a feeling this maybe related to something simple like door latch is not making full closed circuitry or maybe associated door limit switch is defective? As you can see, I am trying to have a sound approach of tackling this issue and would apprecite any insights. You help will be most appreciated.
Maytag has a recall out for several models in your appliance's age group. It was for a wiring issue, a wire harness that can burn and catch wires on fire. They may come out and make the repair/upgrade free of charge. I'd check that first. That may be the reason you mentioned you don't know why the wire burnt. Hope that helps, Tommyboy84
