AppliancePartsPros.com
Appliance Repair Help
Microwave Repair
GE Profile Spacemaker 2.0 Lights, fan, and turntable issue
The lights (Cooktop/Night and Oven) doesn't turn on, the turn-table doesn't spin, and the fan is not coming on. The LCD display comes on and I am able to set the time and set cooking times but when it starts a different hum comes on and it does heat the drinks and the top vent usually Swings open but doesn't. I replaced the 3 halogen bulbs( 2 Cooktop/Night bulbs was burned out but the Oven wasn't but replaced it anyways) and still doesn't turn on. I checked the 2 fuses and the 3 switches(Door Sense, Monitor, and Primary) using an ohmmeter and works fine.
What should I do next or what part do I need to replace or repair
I included the 2 diagrams but from you are saying the 2 parts are as follows: Diagram Location: 21 Part Number: AP3883401 Diagram Location:130 Part Number: AP3883118I am hoping and it seems to be that the problem is with the PCB Sub Asm Part Number: AP3883401Let me know if that is correct, if so I am examining that part right now and doesn't look fried. Does if just go bad? Thanks druiz1 attached the following image(s):
I could not find a pictures for these two boards and unfortunately the diagrams are not very helpful either. There should be a low voltage transformer and a few relays on the board which is responsible for the surface lights, turntable motor and fan. Quote: ...when it starts a different hum comes on... That could be a different problem with a part in the high voltage part of the microwave. I believe the control board should be replaced first. Gene.
Ok I just ordered Diagram Location: 21 Part Number: AP3883401 also known as GE Part Number: WB27X10901 PCB SUB ASM. After some research the other part is GE Part Number: WB27X10900 which is the Smartboard. Will report back once I get the part and test it out. Thanks for your help, I hope that will fix it.
I just got the part which I attached the picture of it here and installed it. Now the microwave is back to working condition. druiz1 attached the following image(s):
I'm glad you were able to fix it. Thank you for the feed back. Have a nice Holiday!
I have the same issue with my microwave. Could you explain to me how you replaced the board. How do you get to the part?
Microwave Repair
