sadiehaflinger
#1 Posted : Tuesday, November 17, 2009 9:51:36 AM(UTC)
sadiehaflinger
I have a 25 year old Hotpoint microwave. It has worked great all these years until now. The start button has quit working. It turns the timer on but not the light or the microwaves. Everything else works like new. Can the start button be replaced or repaired?
applianceman
#2 Posted : Tuesday, November 24, 2009 8:26:25 AM(UTC)
applianceman
For a microwave that old there is a good chance parts are discontinued but on some of those older microwaves the start switch was just a common micro-switch. We need a model number to know any of this for sure. Range Repair Guide
sadiehaflinger
#3 Posted : Wednesday, November 25, 2009 8:15:40 AM(UTC)
sadiehaflinger
Thanks for your reply. The information you requested: Hotpoint Microwave
Model # R E966 001
Manufactured Nov. 1984
applianceman
#4 Posted : Wednesday, November 25, 2009 9:14:31 AM(UTC)
applianceman
After seeing the model number and rereading your post I am almost sure the problem is a loose solder joint on the power module (#1473 on your parts breakdown). If this is the case you can repair the solder joint and the microwave will be repaired. Hope this helps!
applianceman
#5 Posted : Wednesday, November 25, 2009 7:28:48 PM(UTC)
applianceman
I was pressed for time when I answered. It is very common for a solder joint to get loose on this control board. This will cause the problem you describe. Remove the board and look on the backside of it for a loose joint. If you are not comfortable soldering it replace it. Hope this helps!!
Microwave Repair Guide
Here is a link to the part I am talking about Part Details - GE Power module, part number: AP2026570
Guest (4)
