smack
#1 Posted : Friday, November 20, 2009 6:03:41 PM(UTC)
smack
My question is that my dryer over heated a couple of times and then it stopped heating at all.Could it be the thermastat or what?
#2 Posted : Monday, November 23, 2009 6:26:55 AM(UTC)
Replacement parts for DLB1550Balad models | AppliancePartsPros.com
It is near impossible to get info on GE units, they like to keep that info a secret.
Looking at the parts I see 3 thermostat's but cannot tell which one does what. Item 315 and 316 in Section 3 and Item 507 in Section 4.
I would think that one will be the operating thermostat, one a thermal fuse and one a hi-limit thermostat.
Check them all with a meter. All should be 0 ohms at room temperature.
Also could the heating element is blown.
You said it overheated a couple times so it is importatant that you find the cause. If it was not a clogged vent system then I would also replace the operating thermostat if the thermal fuse is blown.
Also check for a grounded element. Remove the wires from the element (noting where they go) and then measure them with a meter, they are usually around 10 to 20 ohms. Then measure from each connector to thye case/frame all should be infinite ohms (open).
Could also be a switch but without a wiring diagram I cannot say which.
