thehun
#1 Posted : Monday, February 18, 2008 11:14:19 AM(UTC)
thehun
the top right button that controls the oven temperature shows oven temperature as its heating up to desired temp, but shuts off as its heating up, thanks, i think its called the clock.......serial number 102138DW
#2 Posted : Tuesday, February 19, 2008 11:46:33 AM(UTC)
Most likely the problem is a bad control board (clock).
In order to provide the right part number for the clock I need to verify the first two digits of the serial number.
thehun
#3 Posted : Tuesday, February 19, 2008 12:07:54 PM(UTC)
thehun
serial no is 102138DW
#4 Posted : Tuesday, February 19, 2008 12:17:09 PM(UTC)
The part number for the control board is AP382903
Here are the break down diagrams for the Maytag range Model CRE775
