We Cleaned Out The Vent Because Clothes Were Taking 2 To 3 Dry Times To Dry Now After About 20 Minutes Into Timed Drying It Shuts Itself Off. Please Help
Here are your parts Replacement parts for AMANA LEA50AW | AppliancePartsPros.comIf you have to wait a few minutes to restart it, then the motor is probably overheating and tripping it's internal thermal protect. Try rotating the drum by hand to ensure it is not overloading the motor. It should turn fairly easily. Unplug it, open the unit up and give the motor, interior and the blower wheel a good cleaning. Also check that the motor's armature turns easily. If it still does it then odds are good that your motor is on it's last legs. |
THIS FORUM IS DEAD!!!!!!! |
