rashley55
#1 Posted : Saturday, November 21, 2009 1:23:11 PM(UTC)
rashley55
My whirlpool duet started flashing the FH error code after running for one minute (filling with water hot,cold or warm ). I hit the pause botton and restarted sometimes it runs the first time or after several tries. I ran the diagnostic test got the fh code at C:01 the first time I ran the test. I reset the washer and restarted it worked good. I cleaned the drain pump filter got a baby sock, 76cents and five pens. Any idea why I still get the fh code sometimes.
sidfink43
#2 Posted : Sunday, November 22, 2009 11:17:15 AM(UTC)
sidfink43
Nobody can figure out what these models are doing, including Whirlpool.
Unplug it for a while and see if that helps.
Good luck.
appliancerepairnovice
#3 Posted : Monday, May 17, 2010 6:05:00 AM(UTC)
Good luck.
MY '05 MODEL WAS DOING THE SAME THING.....BEGIN TO FILL, THEN STOP WITH FH ERROR CODE. WITH THE LID OFF, I WOULD TOUCH EVERY ELECTRICAL PLUG I COULD SEE, TO SNUG THE CONNECTIONS, AND IT WOULD RUN, TROUBLE-FREE...SOMETIMES FOR MONTHS. THEN IT WOULD HAPPEN AGAIN, THEN AGAIN AND AGAIN. EVENTUALLY, THE TOUCHING OF THE ELECTRICAL CONNECTIONS FAILED TO CORRECT THE PROBLEM.
ANY SUGGESTIONS????
ggdave
#4 Posted : Wednesday, November 10, 2010 10:12:58 AM(UTC)
ggdave
Check airtrap. Have to pull out washer as need to remove back cover. airtrap is on lower rt side of tub. put a flashlight tight up to it, if it looks clogged, remove it and clean it with vinegar (or pool acid if you are familiar with it)
This part must be clean, as water enters the tub it creates air pressure in the airtrap, transmits it thru the tube to sensor. if it is clogged, no air pressure, sensor tells control unit no water is entering tub, unit shuts down, displays fh fault.
you will never find this part mentioned in troubleshooting. it can be replaced, part # ap3128817
sidfink43
#5 Posted : Wednesday, November 10, 2010 11:22:29 AM(UTC)
sidfink43
Great tip, thanks
ernie007
#6 Posted : Thursday, November 11, 2010 8:24:24 AM(UTC)
ernie007
My maytag waher model MAV57582ww it will spin, wash, it start on any rutine . HOWEVER only for 20 seconds and all leds turn or flash and shut down stops need help.. try to reset it no help
sidfink43
#7 Posted : Thursday, November 11, 2010 2:44:06 PM(UTC)
sidfink43
Ernie
Please start a new thread and someone may be able to assist you.
Guest (5)
FH error code on Duet front load washer (Washer Repair)
by jimhokie 10/15/2013 3:17:32 PM(UTC)
FH Error Code on Whirlpool Duet Washer (Washer Repair)
by a251172 3/11/2013 5:57:36 AM(UTC)
FH error code (Washer Repair)
by fishfactor 9/13/2008 4:58:54 AM(UTC)
