dmike56
#1 Posted : Monday, February 18, 2008 9:07:14 PM(UTC)
dmike56
wiring burnt out at the lower element. repaired the connection but oven doesn't turn off or thermosat doesn't turn off or regulate the temperture. also notice burnt wire at the back base of the thermostat
#2 Posted : Tuesday, February 19, 2008 4:13:09 PM(UTC)
In order to provide the most accurate advise I need the complete model number of the unit.
Is it safe? Can I use electric oven again after POP noise and breaker tripped? (Oven Repair (including Ranges and Cooktops))
by Guest 3/2/2024 5:41:59 AM(UTC)
KitchenAid builtin electric oven (Oven Repair (including Ranges and Cooktops))
by Guest 1/10/2024 5:07:18 PM(UTC)
F2 Error Code on GE Electric Oven (Oven Repair (including Ranges and Cooktops))
by Guest 9/11/2023 6:33:44 PM(UTC)
Whirlpool Electric Oven Convect Broil (Oven Repair (including Ranges and Cooktops))
by Guest 8/12/2022 8:27:28 AM(UTC)
GE Electric Oven - Won't stay on (Oven Repair (including Ranges and Cooktops))
by tstwingirls@yahoo.com 2/23/2022 3:51:15 PM(UTC)
Frigidaire electric oven model number PLEF489CCF (Oven Repair (including Ranges and Cooktops))
by Guest 7/25/2021 4:06:10 AM(UTC)
LG LSE3092 Electric Oven (Oven Repair (including Ranges and Cooktops))
by cycle70 4/10/2021 11:11:00 AM(UTC)
GE Profile electric oven will not turn on (Oven Repair (including Ranges and Cooktops))
by toddlamp 3/31/2021 7:03:39 PM(UTC)
ge tru-temp electric oven (Oven Repair (including Ranges and Cooktops))
by Guest 3/17/2021 4:26:18 PM(UTC)
Monogram electric oven not heating (Oven Repair (including Ranges and Cooktops))
by Norploc 2/26/2021 12:56:03 PM(UTC)
ZLINE RA36 ELECTRIC OVEN (Oven Repair (including Ranges and Cooktops))
by AndyGray 1/21/2021 5:13:45 AM(UTC)
Help! GE Profile Electric Oven PT916SMSS (Oven Repair (including Ranges and Cooktops))
by Marsa 5/9/2020 8:36:48 AM(UTC)
Electric oven panel issue? (Oven Repair (including Ranges and Cooktops))
by nhreprops 11/23/2019 10:59:26 AM(UTC)
Can I use the electric oven without the broiler heating element? (Oven Repair (including Ranges and Cooktops))
by Al Thumbs 3/16/2019 10:53:19 AM(UTC)
KitchenAid Electric Oven Won't Heat (Oven Repair (including Ranges and Cooktops))
by frosini 10/1/2018 7:23:00 AM(UTC)
