mcqueary
#1 Posted : Friday, November 20, 2009 9:28:00 AM(UTC)
mcqueary
Need to replace Thermostat but can't get the capillary tube out of the oven. Plate that holds the burners blocks removal of tube because of length of tube.
#2 Posted : Friday, November 20, 2009 12:31:22 PM(UTC)
You have to remove the top panel, the burners, the orifice spuds and the burner box which is secured with a few screws around.
Here are the breakdown diagrams and Replacement parts for GE RGB744GEV2WH | AppliancePartsPros.com
