sologig
#1 Posted : Monday, February 18, 2008 7:32:20 PM(UTC)
sologig
Refridgerator KSRP25F, Side by Side, Stainless Steel
Diagnostics light.
Ice Maker Switch Position = Off
Flapper = extended(Optics obstructed)/retracted(Optics unobstructed)
LED: 2 blinks red/2 blinks red
Ice Maker Switch Position = ON
LED: 2 blinks red/Solid red
Water flows through door dispenser, with adequate pressure. Refridgerator is less than two years old. Until recently, ice maker worked, line became frozen. Line thawed, water flow restored, water flow is present, observed through door dispenser.
No ice but water runs through door service. Was able to defrost some of the black fill tube tonight, some ice out, only a litte water flowing through. I suspect line is still iced in some area. Will likely have to complete defrost.
Any other suggestions?
Thank you for your assistance.
sologig
#2 Posted : Monday, February 18, 2008 7:51:43 PM(UTC)
sologig
Update:
It appears fill line has defrosted enough to flow water into cube form tray. Method of defrost was two fold. First tried a flexible copper strand wire heated with hair dryer, heat conducts through wire.. Second method, kitchen funnel with collection end into fill tube, flare end directs hair driyer heat into fill tube.
Probably just luck but, back in business.
Rheannonr
#3 Posted : Saturday, July 2, 2016 7:42:05 PM(UTC)
Rheannonr
Diagnostics light.
I'm having the same exact problem with the same LED light patterns. Still haven't been able to fix it. Anything new come up for you?
