2 Pages12>
bassdad
#1 Posted : Sunday, November 15, 2009 5:55:10 AM(UTC)
bassdad
cannot get to agitator mounting bolt calls for 5/16 socket but it will not fit in the retainer spring can you help me get this bolt out thankyou
sidfink43
#2 Posted : Monday, November 16, 2009 5:40:40 AM(UTC)
sidfink43
I am not sure where your problem is, but the bolt should be right under the cap, and you probably need to use a 7/16" socket with extension and not a 5/16".
bassdad
#3 Posted : Tuesday, November 17, 2009 4:29:05 PM(UTC)
bassdad
Kenmore Elite Washing Machine 11023014100 (Model #)
You indicated to use a 7/16" sock wrench with extension - that is too large. The problem is I am unable to get the bolt out of the retainer spring to remove agitator to replace the dogs.
sidfink43
#4 Posted : Tuesday, November 17, 2009 4:41:39 PM(UTC)
sidfink43
Ok, I think you are saying you have removed the agitator from the machine but are unable to get the bolt out.
Have you separated the lower agitator from the clothes mover? That should do it for you.
bassdad
#5 Posted : Wednesday, November 18, 2009 5:37:55 PM(UTC)
bassdad
No, I have not removed the agitator. I am unable to get the bolt out of the retainer spring.
sidfink43
#6 Posted : Thursday, November 19, 2009 3:51:03 AM(UTC)
sidfink43
Once the bolt has been unscrewed from the shaft the agitator will lift out even if the bolt is still inside the assembly. You can now lift up the agitator from the tub. The agitator will then separate from the clothes mover so you can get to the parts.
This process is difficult some times because soap and scum has built up but once the screw is no longer in the shaft there is nothing holding the agitator down.
bassdad
#7 Posted : Friday, November 20, 2009 3:43:50 AM(UTC)
bassdad
if iam understanding you i must go from the bottom of the machine
sidfink43
#8 Posted : Friday, November 20, 2009 5:14:20 AM(UTC)
sidfink43
I am afraid I really do not understand what your problem is. Hopefully someone else on the Forum can helpl you.
bassdad
#9 Posted : Friday, November 20, 2009 6:04:56 PM(UTC)
bassdad
my problem is that i have a kenmore #11023014100 the auger is not operating right due to cam dogs being wore out. I need to get the cam out to replace the cam dogs. I need to get the agitator mounting bolt out to accomplish this task. Ive tried 5/16 socket thats to big. there is a retainer spring that has a smaller hole i will try 11/32 if that dont work i will try 9/32 the size of the bolt is the problem. thank you for your help bassdad
gabe_1981
#10 Posted : Friday, November 20, 2009 7:37:02 PM(UTC)
gabe_1981
This link will show you that sidfink43 was tellin you exactly how to remove the aggitator.
YouTube - Broken Whirlpool/Kenmore Washing Machine Agitator Fix
2 Pages12>
