Hi gas oven stoped working igniter was not working I replaced that part with a new one and its not working either it gets power to it and it checks out on the meter Help:)
The model number you posted does not come up. Verify and repost it.
What is the part number for the igniter you replaced?
Im curious to see why a new ignitor is not working when it has power goin to it.
Hi and thanks I couldn't find it either but here it is again Rh2712143 and another #5f312vegw this is the part # for the ignitor and it gets current to it but does not even get warm the new one
The numbers you posted do not look like a valid Whirlpool part or model numbers. The name plate with the model number can be: under the top panel, on the oven door frame or behind the bottom drawer.
thanks here is the model no. 5F312vegw and serial no. rh2712143,and the ignitor part no. ap3104565 I did fine out that the voltage is weak going to the ignitor for oven
The closest model number I found is Model SF312PEWW0
and it has a free standing pilot instead of a glow bar igniter, you mentioned. I can not go further without the correct model number. Gene.
Thanks gene for all your help so far Thats the number the only thing was or maybe confusion about the 5/s I have no idea why it does not come up I'm going to let it go it's begaining to cost to much thanks guys for the help:confused:
