smithbdr
#1 Posted : Monday, February 18, 2008 7:20:20 AM(UTC)
smithbdr
the power will sometimes go out an dif i unplug it, it will come back on and it may act as if there is not enough power things are deem and if i shake the door or tap the side it seems to come on line sometimes. HELP don't want to buy another microwave if all possible:mad:
#2 Posted : Monday, February 18, 2008 4:18:12 PM(UTC)
The first thing I would check are the condition of the door switches and proper door switches engagement by the door latch.
When you said "the power will sometimes go out " you meant the display goes blank?
If this is right then most likely the problem caused by the control board or loose connections to the control board.
The model number you posted is incomplete and I'm not able to provide the right part numbers.
