BEEJAY
#1 Posted : Monday, February 18, 2008 4:06:56 PM(UTC)
BEEJAY
Center frame dividing the freezer and the fridge compartments gets quite hot where the door gaskets sit on. The heat is turning on and off. What is this heater for, what is controlling it and how can the heat be turned lower or if not, turned off completely?;)
#2 Posted : Tuesday, February 19, 2008 2:15:52 PM(UTC)
The first thing I would do is remove the front bottom grille and the rear cover and clean the condenser coil (#3 on the unit break down diagram).
To do this better you need a special condenser coil brush.
Here are the break down diagrams for the Whirlpool refrigerator Model ED25DQXBB00
Guest (4)
