hairysoda
#1 Posted : Monday, February 18, 2008 4:31:01 AM(UTC)
hairysoda
i just unpacked the mircowave and notice that the front of the door has been pushed in a liitle bit on the bottom right of the door. i want to push it back out but when i take the two screws out i still am not able to get into the door. please help as i want to install the microwave and this has be come very frustrating.:confused:
#2 Posted : Monday, February 18, 2008 2:09:05 PM(UTC)
This is a brand new microwave and I do not recommend you to mess with it.
Instead you have to talk to people who sold it to you.
Also the model number you posted is incomplete and I can not see what color is it. If it's stainless steel you'll never make it look like new.
hairysoda
#3 Posted : Monday, February 18, 2008 9:25:33 PM(UTC)
hairysoda
thanks for the quick reply.. the microwave is white not chrome and it is already installed and i would like to try and get the front glass piece to snap back into place. if i can open the door as if i was changing the handle i think i would be able to get access to the front pane and just push it back in place. that is what i would like to do..
#4 Posted : Tuesday, February 19, 2008 7:21:57 AM(UTC)
I hope this video clip and the door break down diagram will help you.
Guest (4)
Black Oven Door Glass, not sure model? (Oven Repair (including Ranges and Cooktops))
by amemary 12/29/2013 1:09:12 PM(UTC)
Oven Door Glass Replacement (Oven Repair (including Ranges and Cooktops))
by Amsel7 11/29/2013 7:26:50 AM(UTC)
lower oven outer door glass (Oven Repair (including Ranges and Cooktops))
by tlkoett@yahoo.com 1/24/2013 9:21:40 AM(UTC)
Door Glass Jenn Air (Oven Repair (including Ranges and Cooktops))
by Chaser72 1/22/2013 9:51:51 AM(UTC)
inner oven door glass broken (Oven Repair (including Ranges and Cooktops))
by 1pooldoc 12/15/2012 4:13:12 PM(UTC)
Clean between door glass (Oven Repair (including Ranges and Cooktops))
by jmeander 11/23/2012 5:23:22 AM(UTC)
Outer Door Glass Replacement (Oven Repair (including Ranges and Cooktops))
by ksouthar 11/15/2012 6:40:58 PM(UTC)
jenn air door glass (Oven Repair (including Ranges and Cooktops))
by dickgordon 11/2/2012 5:01:50 PM(UTC)
cracked inner oven door glass (Oven Repair (including Ranges and Cooktops))
by debbl1412 7/19/2012 9:34:49 AM(UTC)
discolored door glass (Microwave Repair)
by goldov 6/21/2012 11:38:11 AM(UTC)
Replace inner door glass (Oven Repair (including Ranges and Cooktops))
by Melanie Adk 6/16/2012 11:32:41 AM(UTC)
Softener spilled in front door glass of washer (Washer Repair)
by Cheryl926 4/12/2012 8:45:10 PM(UTC)
Kitchenaid Oven Door Glass Replacement (Oven Repair (including Ranges and Cooktops))
by drill 1/6/2012 5:48:30 AM(UTC)
electrical oven door glass (Oven Repair (including Ranges and Cooktops))
by RTOates 1/1/2012 6:57:27 PM(UTC)
by EDDOLL 10/31/2011 9:29:05 AM(UTC)
