2 Pages12>
wiskyhome
#1 Posted : 15 years ago
wiskyhome
Our fridge is 4 yrs old and the ice maker quit. I tried a hair dryer on the water tube in freezer with no luck.We still get water out of the water dispencer but the pressure seems a little weak to me. I pulled out the fridge and seem to have good pressure coming in from the pipes when i turn the valve on.I pulled the (4389177) filter valve and disconnected the tubes coming from the filter and there was a little water.We just put a new water filter in about 2 weeks ago. I am thinking that either the Filter valve assy is bad or the part# 6266653 module assy inside the freezer is bad. If the filter is bad is it just a matter if disconnecting the tubes and plugs? or more to it.It seems like it would be about a 10-20 minute job.Thanks for your help in advance.
#2 Posted : 15 years ago
Make sure the ice maker "on-off" switch on the right side is in "on" position. Open the freezer door, press in the emitter flapper door (on the left side) to unblock the optics beam and view the diagnostics "status" LED on the right side. Post the results.
wiskyhome
#3 Posted : 15 years ago
wiskyhome
I pushed in the flap opened the flap by the ice maker so the light in the freezer went off,and the flap on the left side of the fridge and the red led light pulsed/flashed on for a second and off for a second for the 20-30 seconds i monitored it
wiskyhome
#4 Posted : 15 years ago
wiskyhome
I went back an hour later closed the flap on the lfet and the red light next to the on/off switch just stayed on
#5 Posted : 15 years ago
According to your replies the optics are not stable and very likely are bad.
Remove the ice maker and check for 120VAC between the black and white wires at the plug.
wiskyhome
#6 Posted : 15 years ago
wiskyhome
Is that easy to get out. Just the bolts inside the freezer compartment?
#7 Posted : 15 years ago
Remove the wire shield screw from the bottom of the ice maker.
From the rear of the ice maker, lift the top of the wire shield slightly and pull it
back to release it from the ice maker. Press up on the two retaining clips (one on each side) at the bottom of the ice maker tracks with a fingernail of each hand, pull the ice maker forward, and remove it.
Unplug the wiring harness connector from the ice maker.
wiskyhome
#8 Posted : 15 years ago
wiskyhome
Thank you i will try it and post the results
wiskyhome
#9 Posted : 15 years ago
wiskyhome
I pulled the ice maker and tested the wires 3 times and each time the reading was 108.8. Sorry for the delayed reply i was out of town for a bit.
#10 Posted : 15 years ago
Do the following test:
Make sure the "on-off" switch on the right side is "on". Remove the ice maker head cover (do not unplug the ice maker). Insert the voltmeter test probes in the "N" & "L" ice maker test points. Make sure the test probes are at least 1/2" in. Push in and hold the door light switch and wait at least 5 seconds before the voltage test. Post the results.
Ice Maker Not Making Ice At All Times (Refrigerator & Freezer Repair)
by danrclem 2 years ago
Whirlpool WRF535SMBM00 Ice maker not making ice (Refrigerator & Freezer Repair)
by Derek Halter 2 years ago
LG Refrigerator LFX21960ST Ice maker not making ice (Refrigerator & Freezer Repair)
by tfmc369 2 years ago
Under Counter Ice Maker not making ice (Refrigerator & Freezer Repair)
by ling_appliance 3 years ago
FRS26KF6EM4 Ice Maker not making ice (Refrigerator & Freezer Repair)
by johnhurst 3 years ago
Maytag ice maker not making ice, I don’t know what else to try... (Refrigerator & Freezer Repair)
by Karnsky 4 years ago
Whirlpool Ice Maker Not Making Ice (Refrigerator & Freezer Repair)
by hanginghelmet 9 years ago
Whirlpool Ice Maker not making ice (Refrigerator & Freezer Repair)
by turbotribes 10 years ago
by kidmims 10 years ago
Ice Maker not making Ice. (Refrigerator & Freezer Repair)
by atticus1 10 years ago
by gaff 11 years ago
Ice maker Not making ice (Refrigerator & Freezer Repair)
by chavisfamily1234 12 years ago
by cgoodwin 13 years ago
by Guido 13 years ago
Kenmore Ice Maker not making Ice (Refrigerator & Freezer Repair)
by ghauptman 13 years ago
2 Pages12>
