Rustyinmonroe
#1 Posted : Monday, November 16, 2009 2:44:42 PM(UTC)
Rustyinmonroe
Hello all,
My machine is a Performa, and it just started acting up yesterday. It fills correctly but when it gets to the spin cycle, it makes a really loud grinding type noise and will not spin, nor drain. Any help would be appreciated. Working on a small budget here. :)
Rusty
sidfink43
#2 Posted : Wednesday, November 18, 2009 8:45:11 AM(UTC)
sidfink43
Let's hope the problem is in the pump. Take it off and check it out, and check for any obstruction or damage in the pump.
Here is a service manual which will show you how.
http://www.servicematters.com/m...ibrary/docs/16026502.pdf
and here is a tech bulletin on the new type of pump. Presumably Maytag redesigned the pump because of problems, and hopefully that is your problem, because otherwise you are looking at transmission/brake issues, which is not good.
http://www.servicematters.com/m...ary/docs/ITDL-0031-B.pdf
Rustyinmonroe
#3 Posted : Wednesday, November 18, 2009 5:41:36 PM(UTC)
Rustyinmonroe
Thanks, will open it up and see this weekend. :)
Rusty
