2 Pages<12
bboustany
#11 Posted : Tuesday, November 10, 2009 5:10:03 PM(UTC)
bboustany
Thank you very much for your help. I will order the part tonight and let you know what happens. Thanks again.
If the EOC has incoming power but nothing goes out then the EOC most likely is bad.
- The EOC Part number: AP3874704
#12 Posted : Tuesday, November 10, 2009 5:22:54 PM(UTC)
Good luck.
bboustany
#13 Posted : Wednesday, November 18, 2009 5:57:52 AM(UTC)
bboustany
Gene:
I changed the EOC. The F20 is gone and the range works perfectly. The cooktop doesnt work still. It has power going to the controllers but when you turn them on nothing happens. Any ideas?
BB
bboustany
#14 Posted : Wednesday, November 18, 2009 5:58:28 AM(UTC)
bboustany
Is there a reset botton or something?
THanks,
Originally Posted by: bboustany Go to Quoted Post
Gene:
BB
#15 Posted : Wednesday, November 18, 2009 11:26:34 AM(UTC)
There are no reset buttons and/or fuses. Most likely the problem is a bad power supply board (#99 on the diagram). It provides power for all surface elements control boards.
- The power supply board Part number: AP3874766
2 Pages<12
