stansiegel
#1 Posted : Monday, November 16, 2009 3:26:31 PM(UTC)
stansiegel
It appears that the lint screen may not be catching all the lint that it should. There is a lot of lint ending up in the exhaust hose that builds up over time. What could be the cause?
#2 Posted : Tuesday, November 17, 2009 7:22:57 AM(UTC)
Lint filters never catch all the lint. You probably have already checker that it is not ripped and that it fits correctly in the holder.
Depends over what time frame it is building up as to whether is is abnormal.
Possible causes could be
1. A dirty or loose blower wheel, not pushing the air out with enough speed
2. Exterior vent louvers not opening up all the way slowing down the air flow.
3. A vent system with a number of 90 degree turns.
4. A vent system with a long run of corrugated plastic vent tubing which likes to hold lint.
5. A vent system that is under-sized.
6. A vent system that is crushed causing an air flow restriction.
stansiegel
#3 Posted : Tuesday, November 17, 2009 6:00:16 PM(UTC)
stansiegel
The lint screen is not torn. It gets cleaned before each load but it just doesn't seem to get filled up with much lint.
#4 Posted : Tuesday, November 17, 2009 6:54:53 PM(UTC)
Only thing I can think of that would bypass the lint filter but still get the lint into the venting is a cracked filter housing.
If you have a front load washing machine the clothes will have less lint than a top load.
stansiegel
#5 Posted : Wednesday, November 18, 2009 5:08:29 AM(UTC)
stansiegel
The washing machine is top loading. There is no seal between the lint filter and it's housing. Is there supposed to be one?
#6 Posted : Wednesday, November 18, 2009 10:48:25 AM(UTC)
Not as far as I know.
