kemily
#1 Posted : Saturday, September 15, 2007 4:47:08 PM(UTC)
kemily
the drum in my washer goes off balance, it seems in one location and bangs against the sides. How do i figure out if it's springs, shocks or the shell (or something else)?
#2 Posted : Sunday, September 16, 2007 1:39:07 AM(UTC)
Go to appliancepartspros.com for take apart info and check your shocks and springs. You can get parts by clicking on your model # above.
JEFFREYROBERT
#3 Posted : Tuesday, December 18, 2007 2:02:12 PM(UTC)
JEFFREYROBERT
More Than Likely The Drum Mount Is Broke In The Back. This Is Common On These Machines. Gam Ahold Of One Edge Of The Drum As You Rotate It To Several Different Positions. If The Drum Mount Is Broke It Will Move To The Side In One Position But Not In The Other. The Drum Is Mounted On A Bracket On 3 Locations. If This Is It, It Should Have A 25 Year Warrenty But Not For Labor.
Kenmore No More
#4 Posted : Friday, October 23, 2009 4:56:54 AM(UTC)
Kenmore No More
The "drum mount" referenced on Kenmore front-loaders - this "3-location" description - seems to indicate it's a "cage" bolted to the very back of the drum itself - a part INTERNAL to the entire drum assembly ... and isn't a D.I.Y. job. You'll likely need a new "tub-spin" assembly ... which costs more than a brand new, high-end washer after the technician labor kicks in. My former Kenmore (417.29042992) didn't show this "3-location" drum *holder* available as a separate piece ...
But ... before you throw too much money into a repair - and you *DO* realize that these modern, rather expensive washers / dryers *ARE* simply "throw-away" items, don't you? - check the level / shock absorbers - mounted at 5 and 7 o'clock on each lower side of the drum as you're facing the front door.
When one breaks - and many do - this throws the whole machine outta whack and that's generally the cause of the initial "banging" of a drum. Using the machine after that only leads to MORE damage - usually fatal to the machine as far as $$$. One banging? VERY bad. More bangings? Death of the machine is imminent.
A pair of shocks are 25-40 bucks - and an easy D.I.Y. job - and may allow you to extend the life of YOUR particular machine if something more serious hasn't already been destroyed - but you can never wash many unbalanced loads - i.e. VERY large, absorbent items such as a super-thick bath mat - inside the drum - EVER again. Once a drum has banged, it's a sign that it's gonna happen again ... and it'll be easier to happen than before and will continue to "eat" itself to death.
Good luck! Me and my new Samsung 328 with VRT (Vibration Reduction Technology) will say a prayer for both you and your older Kenmore ('cuz you're gonna need it!)
supergbp
#5 Posted : Tuesday, November 17, 2009 4:25:13 PM(UTC)
supergbp
I have the same prob. I order the shock absorbers. But I think there is something wrong with the basket. It seems loose. I am not sure how to remove it from the outer tub assembly. Going to try and remove it for the second time. Could be more problems after reading the last post. Great info here, thank you.
Cork9202
#6 Posted : Friday, May 30, 2014 5:59:47 PM(UTC)
Cork9202
I have the same issue with my washer, it has had problems since the day I bought it. The thing slams the sides so badly that it walks across the room. The source of the problem is that they failed to install upper springs on the tub. The schematics only show the suspension rods but there are supposed to be springs that attach to the upper part of the tub and the suspension rods. Sears will never get another penny of my money. A$$HOLES.
