juventus
#1 Posted : Tuesday, November 3, 2009 9:11:57 AM(UTC)
juventus
I replaced the drum slides but after running a couple of perfect loads, the drier stops after about one minute. It restarts right away but stops again after running a very short while. It does so a couple of times more and than it won't start again unless I wait a while. Now as I write this it seems to be running fine. Bad thermostat? If so whitch one as there seem to be a few.
sidfink43
#2 Posted : Thursday, November 5, 2009 3:43:39 PM(UTC)
sidfink43
If it happens again open it up and check the connections on the door switch. You may have loosened one of them in replacing the glides.
juventus
#3 Posted : Tuesday, November 17, 2009 2:53:08 PM(UTC)
juventus
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
