Stove top works fine, broiler works. The oven will fire up but the temperature varies. It will not go above 325. I just want to know where to start. Thanksgiving is coming and it will not cook a turkey at this rate.
From what I gather I will check the oven sensor for 1100 ohm at room temp. Any other ideas?
