chezfritz
#1 Posted : Wednesday, December 19, 2007 11:10:03 AM(UTC)
chezfritz
The "heavy" light is blinking, but nothing is happening. If I push buttons, the "lock out" light blinks. If I hold "air dry" to unlock, that doesn't work. Info I've gotten web surfing suggests that I need to replace the control panel, but also that that might not solve the problem. The control panel costs around $150 plus shipping, and I can't return it once I've installed it. So: anybody know how likely it is that a new control panel would fix it? Or got other suggestions? Thanks.
#2 Posted : Wednesday, December 19, 2007 12:43:06 PM(UTC)
Most likely the problem with your dishwasher is not a console which is just cosmetic part, but the display switch (#5 on the frame and console break down diagram).
- The part number for the display switch is AP3010850
- Here are the break down diagrams for the Whirlpool dishwasher Model DU980QPDB6
Good luck.
chezfritz
#3 Posted : Wednesday, December 19, 2007 1:06:33 PM(UTC)
chezfritz
thanks. Do you think I can be confident that the problem is part 5 and not part 3? 3 is the one I meant as "control panel."
Four20
#4 Posted : Sunday, February 17, 2008 7:42:20 AM(UTC)
Four20
im stuck on the same problem here fo the price of the board and the pannel im thinkin new dishwasher...lol
#5 Posted : Tuesday, February 19, 2008 7:25:24 AM(UTC)
Hi Four20,
In order to provide the most accurate advise I need the complete model number of the dishwasher and as much as possible information describing the problem.
Replace control panel? (Dishwasher Repair)
by merple 6/8/2011 10:41:51 AM(UTC)
