Sensible
#1 Posted : Saturday, February 16, 2008 8:00:41 PM(UTC)
Sensible
I'm refurbishing the tub on this 30-year old machine, and there's some rust around the gasket holding the manifold trap (tub drain). I want to remove the trap so I can refinish this opening.
My Kenmore belt drives repair manual shows a trap, and a replacement tub without it, but doesn't mention how to attach or detach the trap assembly from the tub. Anyone know how, without damaging the trap?
Although functionally the same as the manifold trap shown in my manual, it differs from the manual's picture. Mine is a white plastic tube inside a formed black rubber part. The black rubber includes the outlet hose connection, and the whole assembly is held in place by either a rubber gasket or the top of the rubbery part, I'm not sure.)
I suppose I could remove the trap by deforming the gasket section with a big screwdriver, but that would probably damage it and I don't have a replacement. I've removed the outlet hose, and the trap turns 360 degrees but doesn't seem to be screwed or slotted in.
#2 Posted : Sunday, February 17, 2008 2:07:49 AM(UTC)
Lay the washer on its front and loosen the screw clamp around the pin trap, then remove trap.
Sensible
#3 Posted : Sunday, February 17, 2008 8:50:15 AM(UTC)
Sensible
Thanks, but that's not it. It seems there might be two types, your type being as described in the repair manual.
Mine is different. There's a hose clamp (OEM spring clamp, not screw-type) around the connection to the pump, but no clamp at the top of the trap, where it meets the tub. Looks like the black rubber that forms the trap extends into the tub, forming a gasket. Viewed from the top of the trap (from inside the tub), this assembly appears as a black gasket ring surrounding a white ring (the top of the white plastic tubelike structure that's inside the rubber exterior). No hose, no seam, no clamp.
The outer tub is already removed from my washer, so that's not an issue.
(BTW, I'm assuming "pin trap" and "manifold trap" are the same thing.)
