Belt came off when I was taking apart dryer to replace motor blower. Is there a diagrams (current) to show where and how to put belt back on? how do i get belt over drum
Please Help
A good look at how dat belt oughta be if installed all propah.
Once belt is over drum and pully is the belt suppose to fit secure (tight) or loose
Tight. If it is loose it would not turn the drum with wet clothes. The ribbed side goes to the drum; installing the slick side will make it slip too.
Can a belt be stretch out of place, because I've done everything and it want fit tight, unless I'm not putting it around the pully correct
That idler is trying to pull towards the wall right? Ya gotta yank it from the wall until the belt can be put on that idler wheel and when ya lets it all go that thar idler will keep everything taught. Keep in mind this is looking from the rear.You probably aint got a rear hatch on yer model. You gotta go from the front. It is best to have this puppy on a tail gate of a truck where you can sit down and do it from the front. Trying to tilt it back or lay on the floor won't do it.
