Hello. I just bought a place and I am guessing on the age of the dishwasher, bu tthe model is correct. The problem with it seems to be that sometimes it fills with water and works fine, sometimes there is no water. Every time I run it, I can hear switches clicking and motors humming, but only sometimes do I hear water filing the tub (and when I don't, the dishes come out dry and the soap is still in the tub, so I'm sure the problem is no water filing the tub. I tried to pull the unit out the other day to see if there was an obvious problem, but I couldn't even do that. I found 2 screws going into the underside of the counter top and removed them, but the unit would only slide out 1" or so before stopping. I have 2 questions:
1) can anyone point me toward how to test/replace any parts that may be associated with getting water into the tub
2) can anyone tell me how to remove the unit
I will most likely be remodeling the kithcen within the next year, but would like to get this thing dependable for the short term. Any advice is greatly appreciated!!
Groups:: Senior Expert
You have posted on the washing machine Forum. If you will repost on the Dishwasher Forum I am sure someone can help you.
sorry about that. I just reposted. Can someone delete this thread? I don't seem to be able to do that.
