Hi. I am unable to figure out why I cannot get the undermicrowave lights or the above range lights to work. I have changed the light bulbs and took the bottom cover off and all the electrical connections are intact. Is there a fuse somewhere? Thanks for the help
I too have the exact same problem. Is there a fix?
My mircrowave is a Whirlpool, Model Number: MH7130XEQ.
If there are new light bulbs, but the surface lights are not working, then the problem most likely is a bad control board. - The control board Part number: AP3119784
