kirktaylor2001
#1 Posted : Saturday, November 14, 2009 8:05:38 AM(UTC)
kirktaylor2001
The dryer has stopped heating. Everything else appears to be woring fine
#2 Posted : Sunday, November 15, 2009 1:39:34 AM(UTC)
A Model Number may help others help you.
Flip your breaker off/on slowly a couple times. Sometimes you can loose half the line without tripping the breaker and the heating element requires the full 240 volts.
Better yet measure it at the plug with a meter, L1 to L2 should be 240 volts.
Next would be to unplug the unit and check that the wires at the terminal block are OK
Next check for a blown heater.
Then you have the heater thermal fuse, if it has one and the thermostats
