davisroy
#1 Posted : Wednesday, November 11, 2009 9:01:42 AM(UTC)
davisroy
My Kenmore dryer takes forever to dry on the High level, especially when
drying towels. I've checked for lint backup and checked breakers and A/C.
Should I replace the heater, and thermostats? Can you provide step by step instructions.
Thanks...... RLD
sidfink43
#2 Posted : Thursday, November 12, 2009 3:01:51 PM(UTC)
sidfink43
Hi RLD
The first thing I would recommend is that you take off the lint chute by taking out the two screws that hold it to the cabinet that are under the lint door and by taking off the back. The top will now flip up by inserting a screw driver and prying up from the front. Then clean lint chute out completely, and clean out the air intakes and outflow grills in the dryer and all the lint you find inside the cabinet. Finally make sure the vent to the outside is clear.
Put things back together and see if this helps. If not, repost and we will have some more suggestions about testing and replacing parts.
davisroy
#3 Posted : Friday, November 13, 2009 10:26:11 AM(UTC)
davisroy
Ok thanks. I've already done most of the cleaning, plus I've done a continuity check on the heater and thermostats. My wife seems to think the washer isn't wringing water out like it used to. It's an old washer, so maybe I'll take a look at that. It you think of anything else drop me a line.
Thanks again
sidfink43
#4 Posted : Friday, November 13, 2009 2:57:34 PM(UTC)
sidfink43
Ok, try this. The next time you wash a load, leave it in and put the washer on final spin. That should get the clothes pretty close to where they would be if the washer were operating correctly. Then put them in the dryer and see if the dry time is normal.
Electric Admiral Dryer heating problems. (Dryer Repair)
by ShaneBurle24 7/12/2018 8:32:23 AM(UTC)
Whirlpool Gas Dryer Heating Problem (Dryer Repair)
by rinkugaya 9/24/2016 3:17:35 PM(UTC)
Dryer heating problem (Dryer Repair)
by Doehr 8/28/2016 10:41:56 AM(UTC)
Roper dryer heating problems (Dryer Repair)
by laurencp72 1/19/2016 4:58:28 PM(UTC)
maytag stacked Dryer heating problem. (Dryer Repair)
by yudule 8/13/2013 10:30:40 AM(UTC)
by HOLLYTIM 6/11/2013 5:41:18 AM(UTC)
Need more help with dryer heating problems (Dryer Repair)
by Steves9411 4/12/2013 4:53:45 AM(UTC)
by jeeprunner81 5/6/2011 8:54:00 AM(UTC)
by pecos 1/19/2011 8:15:26 PM(UTC)
kenmore dryer heating problem (Dryer Repair)
by glc4122 10/19/2010 5:54:26 AM(UTC)
Maytag MLE2000AYW dryer heating problem (Dryer Repair)
by jgram 9/4/2009 4:56:48 AM(UTC)
Whirpool dryer heating problem (Dryer Repair)
by windsordan 7/30/2009 7:25:42 AM(UTC)
by RARMSTRONG@ADELPHIA.NET 12/9/2007 2:05:55 PM(UTC)
gas dryer heating problem (Dryer Repair)
by sakks 9/13/2007 10:48:37 AM(UTC)
