Pennell
#1 Posted : Thursday, November 12, 2009 5:29:58 PM(UTC)
Pennell
Dryer put in climate controlled storage 2 years ago. Recently placed in apartment and new cord installed to match outlet which was confirmed to be hot. Dial is turned and pressed but nothing happens, no sound, no lights, nothing. Double checked new cord connections. How can I trouble shoot. Is "start" light supposed to come on when plugged in? Dryer looks excellent but remains silent!
Pennell
#2 Posted : Thursday, November 12, 2009 5:30:55 PM(UTC)
Pennell
#3 Posted : Friday, November 13, 2009 2:43:38 AM(UTC)
Here are your parts includes a wiring diagram
Replacement parts for MAYTAG PYET244AYW | AppliancePartsPros.com
Sorry but I do not see a start light anywhere in the wiring diagram or the parts breakdown.
Was the power checked with a meter.
You need 120 volts between L1 and Neutral.
Your start circuit is fairly simple and can be checked with a meter.
Circuit path: NEUTRAL , THERMAL FUSE , DOOR SWITCH , MOT0R PROTECTOR , RUN & AUX motor windings , PUSH TO START switch , L/M timer contacts , L1
The door switch, thermal fuse and the start switch would be the most likely.
