The oven works fine and the buttons all work, however the display panel does not work to show time or temp. Do I need a whole new control panel or just replace the clock assy panel?:confused:
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: tychaney  The oven works fine and the buttons all work, however the display panel does not work to show time or temp. Do I need a whole new control panel or just replace the clock assy panel?:confused: Our Jenn-Air model W142 lost all illuminated windows and clock; appears to operate normal. What needs to be checked/replaced?:confused:
BobBetty
Please start your own post using POST NEW TOPIC. Adding to another persons post when your Model Number is different will just confuse things.
PS: Does sound like your control board/timer needs replacing.
Thanks in advance denman |
