quinn9829
#1 Posted : Thursday, November 12, 2009 6:44:51 AM(UTC)
quinn9829
Dryer will not heat - Whirlpool model LGR6848AZ2. Yesterday, the dryer wouldn't tumble. I changed the belt & it fixed the problem...temporarily. I did 4 loads of laundry just fine. Now the dryer tumbles but has no heat. I tested the outlet w/ multimeter, it's fine. What did I break? Any help would be greatly appreciated! Thanks!
e31430
#2 Posted : Thursday, November 12, 2009 12:21:48 PM(UTC)
e31430
I've attached a tech sheet...(Gas Burners)read it and follow instructions. It will fix your issues.Pages 12-14 if this all checks out then check your thermal fuse and thermostats behind the back panel....they should all read
zero ohms.This info is on the tech sheet attachment page 6
If you get stuck let me know.
Good Luck
K
File Attachment(s):
Tech Sheet - 8545908[1].pdf (412kb) downloaded 36 time(s).
e31430
#3 Posted : Thursday, November 12, 2009 12:41:58 PM(UTC)
e31430
i couldnt get the gas burner sheet to upload so sent this instead.
K
File Attachment(s):
Gas Dryer Not Heating Properly.pdf (29kb) downloaded 19 time(s).
e31430
#4 Posted : Thursday, November 12, 2009 1:09:49 PM(UTC)
e31430
How To Check Dryer Parts For Continuity
see administrators post for this info
