hcover7
#1 Posted : Tuesday, November 10, 2009 2:37:19 PM(UTC)
hcover7
I have a GU940SCGB Whirlpool dishwasher. The soap dispenser does not "pop" during a wash cycle. The plastic actuator works fine, has all springs etc.
It has a wax motor, #AP3044293, which has 3 prongs. Can I test this for continuity? I tried, but got no continuity, figured this was my problem. I bought a new wax motor, and tested this for continuity. Got nothing. Went ahead and replaced old wax motor, still have the same problem. Could my new wax motor be defective?
I understand that the timer governs the wax motor. Can you tell me what parts, if any, might be bad on the control board?
#2 Posted : Tuesday, November 10, 2009 5:44:20 PM(UTC)
http://www.servicematters.com/d...0Sheet%20-%208066008.pdf
The above is the tech sheet for a CGB0 or CGB1
This may also help
https://secured.whirlpoo...510938/$FILE/4322430.pdf
I think you were looking at the dual wax motor.
Could it be that you did not use a high enough meter scale so it read as an open.
Seems strange that both motors would fail at the same time.
hcover7
#3 Posted : Wednesday, November 11, 2009 4:10:49 AM(UTC)
hcover7
Thanks for getting back so quickly. I believe that I did read the meter incorrectly. When I have it set at RX 10K, I get a reading of 2.8. It doesn't matter which 2 of the 3 prongs I touch.
The links you specified look like they may help. It appears that the item P2-3 in the wiring diagram could be a suspect. I have a lot to learn, but I'll pursue this.
Thanks again,
Herb
#4 Posted : Thursday, November 12, 2009 3:54:47 AM(UTC)
You may be reading an alternate/parallel circuit path.
Always a good idea to disconnect the device when reading ohms to eliminate the possibility of the above.
hcover7
#5 Posted : Friday, November 20, 2009 1:40:30 PM(UTC)
hcover7
Hi, I looked at the diagram at the web site you gave me, http://www.servicematters.com/d...0Sheet%20-%208066008.pdf. There is a wiring diagram on page 1. I don't know how to read it. On the left there is a symbol Q1 that feeds to P2-3, then O-BK, then a zig zag that says 600-1800, then feeds to the the dual wax motor to trigger the soap dispenser
I guess this means that there is an orange and black wire that passes through a resistor that varies from 600 to 1800 ohms. If the resistor is open, perhaps the current never gets to the wax motor.
If it's not the resistor, then what else could it be? What does the Q1 mean? Does that represent a component on the control board?
Thanks alot,
Herb
#6 Posted : Sunday, November 22, 2009 2:05:55 PM(UTC)
It is a the heater inside the wax motor, re: melts the wax.
Q1 is a triac. It is a solid state device that passes current when activated.
Basically a solid state relay.
Yes
Guest (6)
Kitchenaid Dishwasher soap dispenser won't open during cycle (Dishwasher Repair)
by dawnbeaufort@gmail.com 12/18/2015 3:22:47 PM(UTC)
maytag soap dispenser won't open (Dishwasher Repair)
by jjleip11 9/15/2013 1:44:50 PM(UTC)
Bosch dishwasher soap dispenser won't open (Dishwasher Repair)
by jbuckley1 1/19/2012 5:55:14 AM(UTC)
Whirlpool Dishwasher Soap Dispenser Won't Open During Cycle (Dishwasher Repair)
by Dr_Zoidberg57 9/1/2010 11:22:54 AM(UTC)
by chwu999 5/18/2008 8:56:09 PM(UTC)
by Badnews 5/11/2008 7:13:35 PM(UTC)
Soap dispenser won't open (Dishwasher Repair)
by renochick 1/9/2008 5:42:32 PM(UTC)
by mnbaird 10/24/2007 4:47:01 PM(UTC)
