My dryer stops spinning after about 15 minutes on a normal load. It still runs, just doesn't spin. My husband just replaced the slides, front bearing, and belt. Anyone have any ideas on what the problem might be?
Very unusual, not sure about what to say. If the motor is turning the drum should turn unless the belt is broken.
I am thinking the belt is not on correctly, check that first. If that is not it, when it stops see if the drum will turn easily. If not, open it up and see what the problem is.
If you need more assistance please post the results from above and your full model number.
My husband just checked the belt and it wasn't on right. He took it off and put in on again and now it's working perfectly!!!! Thank you so much!!!!
Great, we always like it when there is a cost free and easy solution
Thanks for the update.
