mamamick
#1 Posted : Thursday, February 14, 2008 10:10:47 AM(UTC)
mamamick
In the mornings we are finding a water puddle on the floor of the right side of the fridge. Must leak when it cycles? Manual is worthless for this topic. I cannot get behind the panel to see if it is the drip pan. Any suggestions?
abbie
#2 Posted : Thursday, February 14, 2008 11:24:36 AM(UTC)
abbie
Sounds Like You Have A Pluged Drain,when It Goes Into Defrost, The Water Is Probably Not Making It To The Defrost Pan,or If It Is Then There A Crack In The Pan.check For A Pluged Drain.
Guest (4)
leaking fridge from the front (Refrigerator & Freezer Repair)
by hat1478@aol.com 4/16/2010 6:05:20 AM(UTC)
Leaking fridge (Refrigerator & Freezer Repair)
by Jason Wain 7/27/2009 8:40:19 AM(UTC)
Leaking Fridge (Refrigerator & Freezer Repair)
by JGA@REMODEL-PARTNER.COM 7/7/2009 1:52:23 PM(UTC)
by Tricatz 4/13/2009 4:11:29 PM(UTC)
leaking fridge (Refrigerator & Freezer Repair)
by mholmes 8/11/2007 2:46:54 PM(UTC)
