MellowMan
#1 Posted : Tuesday, November 10, 2009 1:47:49 AM(UTC)
MellowMan
Hi, My Whirlpool Top Loader Model # LSQ9010LQ0 Vibrates in spin cycle with or without cloths, I have balanced it and their is a 3/4 inch floor under it that i built myself. I have not been able to check for problems since im not a repair man but i believe if i could get a little help on this i might be able to save a few bucks repairing it myself, I was looking threw parts and thought maybe the Spanner nut is bad or someting to do with the Leveling mechanism.
Thanks In Advance :)
#2 Posted : Tuesday, November 10, 2009 6:46:48 AM(UTC)
If it has been doing it from day one prhaps the shipping strap did not release the tub. Here is the install sheet
http://shared.whirlpoolc...ctions%20-%203956025.pdf
Machine base replacement parts for WHIRLPOOL LSQ9010LQ0 | AppliancePartsPros.com
Here is a manual ao Whirlpool direct drive units.
https://secured.whirlpoo...2007475cb/$FILE/L-55.pdf
If the unit is not level after a wash then I would suspect the rear leveling assembly. You should have to pick the rear end up at least 4 inches to change their setting.
Here is a video that may help at least get it opened up.
YouTube - Direct Drive Washing Machine Repair Video Tutorial *Watch in HIGH Quality!*
Could be the pads or the suspension spring.
MellowMan
#3 Posted : Thursday, November 12, 2009 1:30:32 AM(UTC)
MellowMan
Thank you for the great info, the shipping strap was removed on delievery and it's hard to believe but it stays level no matter how much it vibrates. So i think i'll try removing the cover and see what i can find and i'll let get back to you.
Thanks Again :)
washer vibrates on spin cycle only (Washer Repair)
by ronald.reifsteck@comcast. 8/29/2017 8:19:23 AM(UTC)
Washer vibrates violently (Washer Repair)
by 82pontiac 2/18/2017 5:40:36 PM(UTC)
Roper washer vibrates bad (Washer Repair)
by smessner 1/27/2014 6:18:31 PM(UTC)
Washer Vibrates and tub leans to the right-front (Washer Repair)
by squiggy711 6/29/2013 4:43:18 PM(UTC)
Maytag Performa Washer vibrates and walks (Washer Repair)
by Kurt_washer_2012 12/2/2012 5:54:40 PM(UTC)
Whirlpool Duet washer vibrates (Washer Repair)
by WhirlpoolAllen 6/6/2012 5:01:49 PM(UTC)
Whirlpool washer vibrates and walks (Washer Repair)
by Tom S. 2/27/2012 3:09:23 PM(UTC)
washer vibrates during fast spin cycle (Washer Repair)
by pclaypool09 10/11/2011 8:45:10 AM(UTC)
Siemens washer vibrates (Washer Repair)
by Robquin 7/7/2011 12:23:29 AM(UTC)
Washer Vibrates in spin cycle (Washer Repair)
by wbroadw 1/7/2011 12:32:20 PM(UTC)
maytag washer vibrates in spin when empty (Washer Repair)
by allan3367 12/14/2009 5:40:20 PM(UTC)
washer vibratesat end of spin cycle (Washer Repair)
by kgc159 11/23/2009 9:39:47 AM(UTC)
washer vibrates at end of spin cycle (Washer Repair)
by kgc159 11/23/2009 8:22:05 AM(UTC)
washer vibrates and jumps during spin cycle (Washer Repair)
by chase29 6/17/2009 9:18:47 AM(UTC)
Washer vibrates in spin cycle (Washer Repair)
by Poppi68 6/3/2009 12:11:41 PM(UTC)
