eric0561
#1 Posted : Thursday, February 14, 2008 8:09:05 AM(UTC)
eric0561
I have a Frigidaire I bought 3 years ago. It seems like it gets stuck in defrost mode. If I unplug it for 30-45 minutes, it starts working again. I can tell when I need to unplug it because there's a pre-compressor "growl" that's louder than normal, then it clicks off before the fan comes on. Eventually, it just blows warm air in the freezer. I believe its the control-defrost adaptive timer pc board. part # 240545401. A local parts house has it but says if that's not the problem, it's not his problem. I own the part. limited income so I want to be sure. Any suggestions would be greatly appreciated.
#2 Posted : Friday, February 15, 2008 1:57:44 AM(UTC)
Go to web site www.applianceaid.com They will have a test procedure for your adaptive defrost board.
eric0561
#3 Posted : Friday, February 15, 2008 10:57:57 AM(UTC)
eric0561
I don't have any test equipment. I was just wondering if it sounds like that might be the problem.
