asjackman
#1 Posted : Sunday, November 8, 2009 1:20:26 PM(UTC)
asjackman
My Whirlpool washer (WTW5540SQ0) will fill with water, the agitator works, but it will not spin. I only get a hum from the motor.
*I have checked the pump, it spins.
*I have checked the hoses, they're clear of debris
*The motor works during the agitate cycle
*I have removed the agitator, nothing is obstructing
*I can see around the drum, nothing is obstructing it from spinning
Is there a way I can check with this motor?
#2 Posted: : Monday, November 9, 2009 3:08:56 AM(UTC)
Pull the motor and pump off and do the tranny coupler test in my "sticky" "replacing direct drive brake shoes", post results.
asjackman
#3 Posted : Monday, November 9, 2009 9:43:33 AM(UTC)
asjackman
Hopefully I have found the problem. I took the capacitor off, then hooked the motor up, started the spin cycle and manually spun the crank on the motor. It instantly started up. I ordered a new capacitor, much cheaper than a motor. I'll let people know if this works.
#4 Posted : Tuesday, November 10, 2009 2:48:01 AM(UTC)
Very rare these oil filled start capacitors fail, keep us informed if that fixed it.
