Al Marino
#1 Posted : Friday, June 12, 2009 10:14:36 AM(UTC)
Al Marino
On my GE micro model#JVM2070SH001, the buttons of the keymodule GE part #WB27X10725 (Appliance Parts Pros part#AP3792896) have broken. I found a piece of black bakelite or plastic on the range below. And, neither the vent nor boost buttons are spring loaded. Therefore, the exhaust cannot be turned on in the vent or boost mode. They are loose in the housing. The third button (far right) controlling the light, which lights up the range surface below, is still functioning properly. My problem lies in the fact that I do not know how to remove the stainless steel cover overlaying the control and display screen. Could you verify that I need a new key module (part#17 on the parts diagram that I downloaded from GE, In addition, can you guide me as to how to remove the panel, etc. to get at the failed part. I removed the screw beneath to no avail.
Thank you for your time and help.
wallyb
#2 Posted : Monday, November 9, 2009 9:04:50 AM(UTC)
wallyb
why do they charge so much for parts not needed., remove 2 screws on top like you are changing filter then slide left and remove then there is one screw on top right that releases front panel , the $375.00 dollar part , wallyb
bigantny
#3 Posted : Friday, July 2, 2010 9:13:13 AM(UTC)
bigantny
wallyb,
thank you for the help. Followed your instructions and was able to fix the same problem with the touch panel on the microwave.
Guest (4)
